Anuncios
numbering automatically a text
patriciotxk
patriciotxk
Hello, here is my problem... I am working at a project in which there are a lot of in situ piles. I am at the moment numbering each of them, so I createad a circle and I had put a number inside of it and copied that into the following in situ piles. My problem is I have to change the number of each in situ pile manually, which requires a lot of time, so I thougth there must be a better way of doing this, and that is the reason why I am creating this thread. I am uploading a picture of a part of the insitu piles that I currently have in my project, so you have better conditions to help me.
best regards
0 Me gusta
Responder
408 Vistas
6 Respuestas
Respuestas (6)
chriscowgill7373
Something seems to be up with attachments and the forums lately.
There are a couple of methods you can use, I would recommend either creating a macro that will increment the value on insert, or finding one of the many custom lisp routines that will automatically increment numbers as you insert items.
Lee Mac has a very nice one here:
http://www.lee-mac.com/numinc.html
There are some forum posts related to your request:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-text-increment/td-p/7386837
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/simple-incrementing-of-numbers/td-p/...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
0 Me gusta
imadHabash
i suggest to visit this site >> Click << you will found your lost .
Imad Habash
0 Me gusta
S.Faris
You could use TCOUNT to do the automated Sequential numbering. Refer Below links to learn more on the command
TCOUNT (Express Tool)
(Bonus)Also refer to TCIRCLE for adding circle to your numbers
TCIRCLE (Express Tool)
SALMANUL FARIS
patriciotxk
I already used the TCount, it worked in this problem. Thanks for the help.
best regards
0 Me gusta
vinodkl
You could also use this lisp(see attachment) for incremental numbering.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
pendean
Community Legend
Community Legend
This freebie from the Autodesk App store odes so much more than TCOUNT ever could if you need it https://apps.autodesk.com/ACD/en/Detail/Index?id=8051485828049059617&appLang=en&os=Win32_64
0 Me gusta
