Novice - help needed with spiral ramp
Hi, I have not used AutoCAD before, my sole 3D modelling experience to date is TinkerCAD. Wondering if anyone can advise on which AutoCAD package I would need and how to go about the below?
I need to create a ramp that only proceeds a single "level" around a circle, but the whole ramp must touch the surface. Imagine a partial ring (about 1cm gap between start and end) where the start is level with the surface, then the height increases around the ring until the other end is ~1cm tall. I would need to be able to adjust the width of the ring, radius of the circle and start/end heights to fine-tune for the eventual 3D print.
Googling about, I found this conversation on AutoDesk forums that shows the type of ramp I need... how would I go about creating/modifying this in AutoCAD if I get the free trial (and does the trial allow exporting to .STL or .OBJ)?
https://forums.autodesk.com/t5/revit-architecture-forum/the-length-of-ramp/td-p/5686036
MH
