Hi. when i draw line which lineweight 0.50mm or more, the line isn't drawn correctly, because when i draw one line , i see only two thick dots of beginning and end. It problem only with line. With circle work correctly. In the settings lineweight function on .
Solved by pendean. Go to Solution.
Have you installed the required 2024.1 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024: reverting to DirectX11 fixes similar problems for most users.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
