Not Responding When Using Text Edit
No aplicable
I have a job that whenever i use text edit autocad crashes for 1-3 mins (not responding) if properties pallatte is showing. I turn the pallatte off, but then it pops up again as im working as it is used often and inevitably it happens again. Any solutions ?
0 Me gusta
Responder
1.902 Vistas
8 Respuestas
Respuestas (8)
pendean
Community Legend
Community Legend
PROPERTIES? or QPM, the smaller pop-up tool?
AutoCAD version?
Windows version?
0 Me gusta
No aplicable
Windows 7 - Autocad 14, . If the properties window is closed text edit is a little slow but works, if open I get the, not responding sometimes for 3-4 minutes before it opens the text box.
0 Me gusta
nestly2
Is it a standard font/textstyle, or a custom font?  Is the font accessed from a network location or stored on your local hard disk?   Does the problem occur in other drawings using the same font... does it occur in the same or other drawings using a different font?
0 Me gusta
No aplicable
It is a standard text used every day on most jobs on a local office drive. The problem is specific to this job file , some others in the office have the same problem with this drawing and some do not , but not everyone is on running on 2014.
0 Me gusta
pendean
Community Legend
Community Legend
If it is a file-specific problem, fix the file: AUDIT or RECOVER commands, then QSAVE. Also PURGE until nothing is left to PURGE, and if needed WBLOCK out your modelspace content to a new file and INSERT the resulting new file into a working Template file of yours.
Way quicker than any thing attempts at fixing the file without sharing it here for everyone to try.
0 Me gusta
No aplicable
Does your Properties Palette have any transparency to it? If so try to set it to Solid.
0 Me gusta
sham_saqlain89
Community Visitor
Community Visitor
copy a new text and retype annotation. Delete the text you are trying to edit (there is error in that)
0 Me gusta
nrz13
As a test, make a copy of the file and remove everything from the file except one of the troublesome texts. Does the problem still occur with the Properties palette open?
If so, can you share that edited file here?
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
0 Me gusta
