Not able to plot as desired
abdul.raufJJ89F
Message 1 of 8
abdul.raufJJ89F
I want to plot everything in the drawing in black & white (including 0 layer) except one layer .
How can I do that?
Can somebody provide me the LISP for the above?
Replies (7)
Message 2 of 8
S.Faris
A LISP? If you are interested, CTB Method Details below
Create a Plotstyle as per your requirement
More details on PLOTSTYLES : Plot style table settings explained - In Depth & Detailed
HOW TO CREATE PLOT STYLES IN AUTOCAD - RECOMMENDED
Tutorial: Create a plot style (color-dependent)- Recommended
SALMANUL FARIS
Message 3 of 8
user181
Hi @abdul.raufJJ89F   You can set the color of the layer you want to print out in color to a true color instead of an index color.  True colors always print in color.
Message 4 of 8
pendean
Community Legend
Community Legend
MONOCHROME plot style table is right there in the PLOT command pop-up, help yourself.
Message 5 of 8
abdul.raufJJ89F
I want to elaborate my problem,the only layer which I want to plot in color has 4 to 5 block each having different color and that should be plotted.But main issue I am facing is that some of these colors are common to remaining layers,so they are appearing color in plot.Apart from one specific layer(or you can say blocks present in this layer),everything strictly should be printed in Black and White (including default 0 layer) no matter if they share common colors with specific layer that I want colored.
Hoping I am clear!
Message 6 of 8
To expand on user181's suggestion, (manually) set the color of the objects in question to their actual R-G-B value (not the value from the index color on ACAD/Windows color pallette (eg Magenta = 255,0,255, index color 113 = 82,165,124, etc) by doing this, the colors will look identical to objects with the property of Magenta, etc (and plot identically using acad.ctb) , but monochrome.ctb will plot them in color, while objects assigned as Magenta, etc will plot black.
Message 7 of 8
abdul.raufJJ89F
Thanks, it does work for me.
Message 8 of 8
abdul.raufJJ89F
Thanks for your valuable advice.
