Non-Standard Dimension Text Leaders
No aplicable
When a dimension is too large, it pops out on a leader that is angled (yellow), but I want them to always pop out at 90 degrees (blue) without having to manually move them all.
I am not talking about resizing the dimension...this is for after I have selected a size, but the smaller dimension's text does not fit "in-line"
0 Me gusta
Responder
Soluciones aceptadas (1)
1.200 Vistas
6 Respuestas
Respuestas (6)
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you attach a sample file with your leader style?I don't know if I have a solution but I would like to give it a try for you.
John Vellek
0 Me gusta
No aplicable
As far as I can tell they are both the same but one is placed manually.  Try this in the Style manager
This may Help.
0 Me gusta
No aplicable
Sure.  Here is a sample.
0 Me gusta
pendean
Community Legend
Community Legend
You can't fight the problem: it is designed to pop the leader from the dimline at an angle. You will need to customize with overrides if you want a perfectly vertical line-leader as far as I can tell.
0 Me gusta
No aplicable
Solución aceptada
If you go into Dimension Style -> Under the Text Tab -> Text Alignment Change it to Horizontal that fixes it.
This is what I did to your drawing they all came out at 90.
No aplicable
YES!!  It has one downfall, which is that the vertical dimensions will now have horizontal texts, but that is WAY easier to deal with than the angled leaders!!
Thanks you so much!
0 Me gusta
