No running object snaps for "zoom" in modelspace?
ab_c
ab_c
I have a model with a view lines.
In my layout I have a simple viewport. In Layout I activate "Mspace" and handle my model. When I use a "line" command, then my running object snap (for "end") works fine, but when I want to "zoom window", there is no reaction. I have to use the "single osnap end" for every point.
https://autode.sk/30R7vi0
Why?
Is there a basic limitation for zoom in Layout with running objects snap?
cadffm
Nothing to do with Layout/Model/Paperspace/Viewports..
The most of us don't want a running object snap while in Zoom command,
so it is "as designed".
And thats good for 99.99999% of all Zoom-Windows action in the AutoCAD world 😉
You can write your own "Zoom window end end" macro.
Sebastian
vinodkl
You could set the OSNAPCORD to "0" which would let you snap when zooming with window.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
cadffm
A terrible hint in a public forum with  beginners and professional-dreamer"since 20 years"
But would works 😂
Sebastian
ab_c
Thanks to both - have done my daily learning job right now 😄
(the help for osnapcoord gives a description which make it not that easy to see the realation ..)
