No "bind" option for XREFs
Message 1 of 9
In my earlier version of AutoCAD binding xref's was simple to do but now with 2011 version the "bind" option is no longer there. I need to bind an xref into a drawing. I highlight the xref in the list of xref's in the drawing and right click and choose external references and there is no bind option.
All I read in the "search" didn't fully address this.
I'm stuck and I must get past this issue. Please offer suggestions.
Russell
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
If you are using the XREF palette, simply right-click on the xref name there and select your bind option.
Or start up the old command that is like the old AutoCAD version: CLASSICXREF is the name, type it http://www.cad-addict.com/2009/02/autocad-getting-back-old-xref-manager.html
Message 3 of 9
Using the palate to bind makes the xref disappear but will reappear if I thaw all or regen but is still an xref. The classic method I get "..one xref failed to bind due to a problem proxy object...".
Russell
Message 4 of 9
Well, I guess this xref has something that is preventing me from binding so I opened it and did a clipboard copy of it and pasted it into my drawing which does what I need.
pendean, thanks for responding and thanks for the "CLASSICXREF" info, that is what I'm used to seeing.
Russell
Message 5 of 9
marcos_diasYZJ3W
Community Visitor
Community Visitor
Hi there!
I have the same issue in AutoCAD 2022. Bind option not showing.
If i use the suggested command "CLASSICXREF", there is no xref listed, despite there is 1.
Any ideas?
Message 6 of 9
RobDraw
Is there one listed in the XREF pallet?
Rob
Message 7 of 9
pendean
Community Legend
Community Legend
@marcos_diasYZJ3W wrote:
Hi there!
Any ideas?
Show us what you see exactly, since we all can BIND an xref using both commands
Message 8 of 9
marcos_diasYZJ3W
Community Visitor
Community Visitor
And in CLASSICXREF:
Message 9 of 9
RobDraw
That's an image file. It won't show in the classic XREF dialog because it only does .dwgs.
Rob
