No plot margin after adjusting in page manager
Message 1 of 11
Iam getting just a blank sheet on layout 2 after adjusting the sheet size and everything in Page Setup Manager. I should have a plot margin but I have nothing. Im using a hp laptop.
Replies (10)
Message 2 of 11
Alfred.NESWADBA
what paper format have you set? There are formats that are defined without margins (or better margin = 0).
An upload of the drawing with that layout might help.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 3 of 11
hello. I will upload the dwg file
Message 4 of 11
Alfred.NESWADBA
I see the margins in your drawing.
If you don't see them then try to change to another paper format, if you see the margins then I guess you have a modified paper siize "ARCH C (24.00 x 18.00 Inches)" on your system or you have set it to a paper format that does not exist with a standard AutoCAD setup and my AutoCAD changed it during open to the next fitting one.
- alfred -
Alfred NESWADBA
Message 5 of 11
I've never seen it on my laptop but other computers are fine. Could it be the Autocad install? When Ive opened it at school it shows up on a different computer.
Message 6 of 11
pendean
Community Legend
Community Legend
OPTIONS command, DISPLAY tab, post a screenshot from your laptop here or compare it to the same from A desktop where margins are visible.
Message 7 of 11
Alfred.NESWADBA
You tested the same drawing on another workstation or a different drawing?
Have you modified the page-format "ARCH C (24.00 x 18.00 Inch)" for your DWF-plotter configuration?
Do you see the border if you use other plotter and/or other paper formats?
- alfred -
Alfred NESWADBA
Message 8 of 11
yea Ive seen it on other computers just fine. The only thing I did in page manager was change the printer to DWF6e.PLOT.pc3 in order to get the 24x18 sheet
Message 9 of 11
and there it is on a different machine
Message 10 of 11
****FIXED*****
ha..display printable area was turned off in options
Message 11 of 11
Alfred.NESWADBA
That was a real good catch from Dean.
I was irritated as you wrote "on Layout 2" ... that made me thinking on the other layout (in the same drawing, on the same workstation) you see the margins.
Good to know it's working now, - alfred -
Alfred NESWADBA
