No more UCS object in commandlist AutoCad 2021
marcooomen6498
marcooomen6498
I recently installed AutoCad 2021 on my workstation.In AutoCad 2020 there was a UCS object button in my command list. This has disappeared in AutoCad 2021. so I can no more use a UCS object button in my ribbon.
ВeekeeCZ
Search just
object
cadffm
Look to your own picture.
The left command is NOT part of AutoCAD2020, it is inside the CIVIL cuix.
UCS Object is not a predefined command in AutoCAD, also not in 2020
The question is:
Are you using AutoCAD2021? Why not Civil2021?
Need help to create the UCS Object in your ACAD2021 or what is the question?
EDIT: I checked it in CIVIL2021 and it's still there. Same as in 2020, no change.
Sebastian
imadHabash
i think that the answer in your previous attached image . check Source location ( Civil ) . importing settings from other software may cause such an issue.
Imad Habash
marcooomen6498
thanks for reply solved my problem
