New layers not showing properly in the Layer Property Manager and impossible to use without restarting
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello everyone.
When I create a new layer and give it a name (i.e Walls), it doesn't show up in the layer properties manager, if I search by typing the name of the layer (in this case Walls), the search bar shows me a "Layer 1" with the same properties of the one I created.
If i try to rename it again, it doesn't change the name.
If I try to make it current, Autocad still draws new lines on the previous layer I was working on.
Everytime i need to close and open again Autocad to see and use the layer correctly, which is pretty much annoying when I'm in that part of the work in which i need to create different new layers.
How can I solve this bug?
Thank you in advance for your help
