New layers not showing properly in the Layer Property Manager and impossible to use without restarting
mark_limitless
mark_limitless
Hello everyone.
When I create a new layer and give it a name (i.e Walls), it doesn't show up in the layer properties manager, if I search by typing the name of the layer (in this case Walls), the search bar shows me a "Layer 1" with the same properties of the one I created.
If i try to rename it again, it doesn't change the name.
If I try to make it current, Autocad still draws new lines on the previous layer I was working on.
Everytime i need to close and open again Autocad to see and use the layer correctly, which is pretty much annoying when I'm in that part of the work in which i need to create different new layers.
How can I solve this bug?
Thank you in advance for your help
0 Me gusta
Responder
531 Vistas
8 Respuestas
Respuestas (8)
CGBenner
@mark_limitless
Hello and welcome! Can you share what version of AutoCAD you are using where you see this issue?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
0 Me gusta
TomBeauford
Are you using the outdated CLASSICLAYER or the default LAYERPALETTE?
What is the LAYERDLGMODE System Variable set to 1 or 0?
Have you installed the latest updates for your AutoCAD version?
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
0 Me gusta
Kent1Cooper
@mark_limitless wrote:
.... When I create a new layer and give it a name (i.e Walls), it doesn't show up in the layer properties manager, ...
Do you, prhaps, have the Layer Manager's Filter set to only "All Used Layers"?
Then the list won't include Layers with nothing drawn on them [yet].
Kent Cooper, AIA
CGBenner
@mark_limitless Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
0 Me gusta
mark_limitless
I'm using AutoCAD 2025, but I was having the same issue with AutoCAD 2024 as well
0 Me gusta
mark_limitless
I'm using the LAYERPALETTE. I don't like to see the layers from the RIBBON, so I keep open the layer palette (more or less I use the same look of the Autocad for mac 2010, with layer palette and the properties on the right).
LAYERDLGMODE is set to 1.
Autocad 2025 is installed to the latest version.
0 Me gusta
mark_limitless
I use my own filter for the layers, but the problem keeps repeating even if I remove any filter and create a new layer
0 Me gusta
cadffm
I don't know about this issue, so try different things and check out if one can change* the issue.
Same issue in 2024? But on the same PC, or?
From disable all antivirus/defender Software
to restall .net Framework
or back to ACAD:
a. Start AutoCAD in  /SAFEMODE, same issue?
b. Same issue in  a new file, based on acadiso/acad.dwt?
c. "When I create a new layer and give it a name (i.e Walls), it doesn't show up in the layer properties manager"
    How can  do you create a new Layer?
Sebastian
0 Me gusta
