Nesting with AutoCAD
atribo141141
atribo141141
I am curious about nesting with AutoCAD. I have used various third party nesting softwares in the past but am wondering if there are any features within AutoCAD itself that I may not be familiar with that could help me with nesting large projects we manufacture with over 1000 parts. Smaller than those I typically just manually nest them. I've used Pro Nest and Sigmanest in the past but now I'm doing all nests manually. Thanks for any suggestions!
AVCPlugins
Unfortunately, I don't know of any plug-in for nesting contours or solids directly in AutoCAD. I even approached the OptiNest developers with a proposal to create such a plugin together, but did not receive a response. Therefore, I now recommend using the AVC NC Prepare and AVC DXF Export plugins to create flat contours from a 3D model and then export them to DXF files. All nesting and CAM programs can import such contours from DXF. For example, in our production, we managed to export furniture parts to OptiNest. Next, we save the cutting plan again in dxf and then open it in our CAM program (Biesse b-Solid). And, for example, AlphaCAM does not need to create flat contours - it can read solids from DXF. Files with solid parts laid out in the XY plane can also be obtained using the AVC DXF Export plugin.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
atribo141141
Interesting. 3D is more advanced than my needs, I only need 2D. Very basic. Thank you for your comment!
atribo141141
I think we are saying the same thing, only you worded it much better. Optimization is the key phrase I am focused on. Currently trying out nest&cut cloud based nesting website and so far it is adequate and much faster than manual! Thank you for your comment!
lamensterms
+1 interested to hear if anyone has any recommendations for within ACAD
Some recommendations for outside of ACAD:
- deepnest.io (free)
- nestandcut.com (paid with free demo)
