Nested blocks problem
muhendisleman
muhendisleman
There are too many nested blocks in my Autocad drawing. I need to enter the block 4 times to change the layer color of a block. Is there an easier and more practical solution for nested blocks?
pendean
Community Legend
Community Legend
Like this https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/removing-nested-block-from-main-bloc...
or
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/removing-nested-empty-blocks/m-p/108...
Kent1Cooper
In the REFEDIT command, you get a choice of which level of information you want to edit, so you can go directly into editing the nested Block you want to work on, no matter how many levels deep it is.  Pick one:
Same with the BEDIT command, though it doesn't show the nesting structure the way REFEDIT does:
Kent Cooper, AIA
leman_aliyevaK2WX8
Community Visitor
Community Visitor
Thank you very much. With the information you sent, I processed my blocks faster.
leman_aliyevaK2WX8
Community Visitor
Community Visitor
Thank you for the information you gave, but my blocks were deleted with this lisp, my aim was to perform operations on nested blocks without deleting them.
