Nested Block with alignment Parameter not working
ecookeB5HP5
ecookeB5HP5
Hello Everyone,  I'm currently trying to update an elevation maker to better suit our needs and I am running into a snag. I have create an arrow block (Block A)with an alignment parameter, so that way it can follow along the outside of an ellipse.  I have also created another block that has that ellipse with some editable text attributes (Block B).  Now, independently these two blocks work as they should, how ever when I insert Block A into Block B, the two work fine in the block editor mode, however when I go test this block, the alignment parameter from Block A disappears.   I'm not sure what I am missing from this, does anyone know how to make this work?
cadffm
You can't changge Insert properties, if the insert is nested in another block or xref.
No color, no layer abd so on, and no
dynamic parameters and constrains.
It can't work, by logic of what a block and an insert is.
Sorry.
Sebastian
