Needed solution for " ** Application reference missing: ACAD, to AcDbLinetypeTableRecord."
arpansark0544TCX
Message 1 of 8
arpansark0544TCX
Dear All,
I am facing the above issues when I am using REFEDIT command on a particular Block.
I have done a little research why this error is coming.
As per by observation this is happening if you block has a leader with Z not equal  to 0.
If we can remove the Z elevation from the Leader then we can solve the problem.
But unfortunately, I cannot remove the Z elevation from the leader.
If you have any solution to this. kindly share.
Thank you very much.
#autocad #Autodesk
Replies (7)
Message 2 of 8
paullimapa
Have you tried the Flatten command?
Paul Li
IT Specialist
@The Office
Message 3 of 8
Kent1Cooper
Does that mean you are not able to, somehow [it won't let you change the "Vertex Z" values in Properties in your image], or that you need it to stay at its non-zero elevation for some reason?
Kent Cooper, AIA
Message 4 of 8
arpansark0544TCX
YES. I HAVE. TRYIED.
BUT WHEN WE USE FLATTEN ON LEADER IT BREAKS AND CONVERTS INTO POLYLINE.
Message 5 of 8
arpansark0544TCX
Yes Sir, " it won't let you change the "Vertex Z" values in Properties in your image"
Is there any Lisp or command to change the "Vertex Z" values.
Message 6 of 8
paullimapa
Try this code:
https://forums.autodesk.com/t5/autocad-forum/changing-multileader-elevations-to-zero/m-p/8533368/hig...
or this mzero.lsp
(defun c:mzero (/ en)
(while (not en)
 (setq en (entsel "\nSelect Object to Move to zero Elevation "))
) ; while
(command "_.MOVE" (car en) "" "@0,0" "@0,0,1E99" "_.MOVE" "_P" "" "@0,0" "@0,0,-1E99")
) ; defun
http://www.xtracad.com/forum/index.php?topic=5775.0
Paul Li
IT Specialist
@The Office
Message 7 of 8
arpansark0544TCX
Can i request one thing:
Can we batch move all the leader all at one go. instead of selecting one at a time.
Please.
Message 8 of 8
paullimapa
Ok try this minor revision
(defun c:mzero (/ ss)
(while (not ss)
 (princ"\nSelect Objects to Move to Zero Elevation...")
 (setq ss (ssget))
) ; while
(command "_.MOVE" ss "" "@0,0" "@0,0,1E99" "_.MOVE" "_P" "" "@0,0" "@0,0,-1E99")
) ; defun
Paul Li
IT Specialist
@The Office
