Anuncios
Need help with insertion points
No aplicable
Currently working on a job where the GC requires us to ID the insertion poinit.  Never done this before and am having a difficult time finding any information about it online.  The insertion point is the center of the square gray column in the screenshot.  I attached a few screenshots to better explain what i mean.  Can someone please walk me through doing this (maybe directions with screenshots so i can find the commands)?  I'm using AutoCAD 2019.  Thank you!
0 Me gusta
Responder
300 Vistas
1 Respuesta
Respuesta (1)
tramber
Maybe you can use the _DIMORDINATE that gives a X or a Y from the 0,0 point.
Maybe, if your object is a block, you can use the _FIELD command on an object and obtain its X or/and Y of its insertion point from the object category....
I must say that I don't know exactly what you want... but it is surely possible :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
0 Me gusta
