Anuncios
Need Help with 3d Surftrim command
No aplicable
Hello everyone. I am new to the forum and I was hoping that someone could help me out with an issue I am having.
I can not seem to get the surftrim command to work on the object I am drawing and it is quite frustrating. I have seen several videos on youtube on how to use the surftrim command but I still can not get it to work with my drawing.
I have attached a drawing of the 3d object that I made. It is an automotive switch and another "testing" surface consisting of a slab and a couple of solids incorporated into it. I have tried the surftrim command on every object but it still will not work and I don't know why I am having this issue.
The error I keep seeing after selecting a object is "not valid object type" I am not sure why my 3d solid is not a valid object.
Can anyone help me out please?
Thank you.....
0 Me gusta
Responder
Soluciones aceptadas (1)
3.477 Vistas
4 Respuestas
Respuestas (4)
imadHabash
Solución aceptada
Hi and Welcome to AutoDesk Forum,
SURFTRIM command trims portions of a surface where it meets or bisects a curve, region, or another surface. and you have only 3D SOLID objects which it's different of surfaces object, for that this command will not accomplish your need at this 3d solid object. i suggest to use SUBTRACT command HERE that will serve your 3d solid objects.from RIBBON you can found commands for SOLID and SURFACES (see image below)
Good Luck..
Imad Habash
0 Me gusta
No aplicable
Thank you that solved my problem. It took a little time but I got it to work perfectly.Emoticono feliz
0 Me gusta
imadHabash
Glad to hear that Emoticono feliz
Imad Habash
0 Me gusta
mhogewind
Observer
Observer
I am trying to trim surfaces that I created using corridors/assemblies and I am getting the same same error. please advise
0 Me gusta
