Need help please (picture) applied
sully00
Message 1 of 15
sully00
Help please,
how do you draw this I have been almost completed it but the 120 at the top comes up a little short when I connect it to the rest do I need to use absolute coordinates or relative as I am struggling or could some one help thank you
Replies (14)
Message 2 of 15
ВeekeeCZ
Ex. 7:
"but the 120 at the top comes up a little short when I connect it to the rest"
Then you did some mistake because the dimensions on the figure are correct. 260-20-30-20-20-30-20 = 120
"do I need to use absolute coordinates or relative as I am struggling"
You don't. If you put the lower-left corner of the shape to the 0,0, you can use absolute coordinates. Otherwise use relative.
Message 3 of 15
Patchy
Which one has the X and Y coordinates? That is the absolute.
Message 4 of 15
sully00
how would you draw this? I have done it but when I get to the top example 120 it comes up short and I have to increase the length to connect to 20 maybe I am doing something wrong.
Message 5 of 15
sully00
how would you input that on the command line  example -260-20-30-20 etc
Message 6 of 15
Patchy
How would I do it? Draw the outlines,
then offset, connect them using snap and drink my coffee.
Message 7 of 15
ВeekeeCZ
pline
0,0
260,0
260,20
240,40
240,120
210,120
190,140
70,140
Message 8 of 15
sully00
is that correct I tried it and it don't work properly
Message 9 of 15
sully00
gosh that looks complex how did you do that ??
Message 10 of 15
jporter
If you are not required to use the command line then you can use the graphic input with the tracking tool to accomplish this.  Take a look at this video I made for you:  https://autode.sk/3bWHTYz
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 11 of 15
Patchy
It looks complex but it took less than 1 minute to complete.
Yes, the other way is correct.
Message 12 of 15
sully00
just cooking will take a look when I am finished
Message 13 of 15
Kent1Cooper
I would do it with relative coordinates, so I don't need to add up values for further-down-the-road vertices, and so I can start anywhere.  With running object snaps off:
PLINE
{pick a start point -- I'll assume the lower left corner}
W 1.5 {and another Enter for the ending width the same}
@0,20 {the first upward segment from the lower left corner}
@Anonymous,20 {the first diagonal one}
@0,80
@Anonymous,0
@Anonymous,20
@120,0
{...etc...}
Kent Cooper, AIA
Message 14 of 15
sully00
thank you ever so much for your video it worked great
Message 15 of 15
sully00
thank you hope to have help from you again in near future
