Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello guys,
I need a free solution for work because i can't use unlicensed software and the company can't / WON'T pay 400 euros for a single license for a good software.
I used plate'n sheet until recently and it was easy and got the job done. But now that i can't use it anymore i have to search for a free solution that does the same thing....helps me with the unfolding of different shapes.
I've searched the internet high and low and could not find anything similar 😞
Any help would be apreciated.
Thank you.
L.E. I use autocad 2012 on a x64 OS if that matters
There isn't any free from Autodesk that uses for commercial.
Unfold sheets you need Autodesk Inventor or Solid Work.
Your company wants to make money, why do you have to search to get your job done?
Ask your decision maker how he calculates your costs per hour, divide 400 through this cost/hour ... that's the time you have then to
I guess that should make clear if you already have positive experience with a product.
400 € sounds really like the better investment (for me)
- alfred -
Because the company is all about saving costs and making improvements without investing money....
I just need a little more time here and i'm off. Everybody leaves this company after 2-3 years... it's only good to get some experience here.
And the developer, who write software, does not need to survive?
At least: this is a tool that helps to reduce time for construction, isn't it? The time might come and your company will be asked "I look for products like you have, but for free".
SCNR, I do understand every private person not having enough money depending on it's environment, but for companies a tool, that helps in construction process, either with quality or efficiency or both, should pay for that. I'm quite sure your managers aren't working for free, are they?
- alfred -
I would like to share how I would express myself if an innovating company told me
"I don't want to invest in 400 euros for a single license for good software."
But... I don't feel like getting banned from AutoDESK Forums today
Format the hard drive every 30 days and reinstall it.
I still don't get it, other than using this free program they have nothing you can use?
Sounds like this place is not the place to get experience as you mentioned.
VirtualBox is easier than a full OS format, if one were so inclined.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
@Anonymous wrote:... the company is all about saving costs and making improvements ....
Sounds like a really smart company that doesn't like to waste money.
Can you attach an example file here that is representative of your work.
It should come down to a simple addition and subtraction problem (with maybe a bit of multiplication) to show how money is being unintentionally flushed down the drain every day. Once proof can be demonstrated - the company will want to plug this hole if the cost of the plug is less than the loss down the hole.
But if I were company manager - I would want to see example and proofs - attach your example here.
Lots of discussion on costs but there seems to be very little on the other side of the equation: how much business, roughly, does your company do? Whats the average job size, cost-wise? Based on the work description I think there should *not* be a problem getting funding for proper software, unless what you do is a very remote, small side business.
Thank you for mentioning this.
"in fact, if you do find a free solution - more than likely there are terms you (your company actually) has to agree to - and alot of "free" programs cannot be used legally to generate income. Fact. Bring that to your employer."
