NAVAIDS
NAVAIDS
NAVAIDS
HI
Could you helped me with some example drawning  in autocad about navaids on aviation called VOR,NDB
TheCADnoob
Would love to, but we (or at least I) am going to need a little more information about what you are doing.
CADnoob
Hi
I want to make one aviation drawings
with insert navaids equipments for example NDB,VOR ect,so I need for one model
TheCADnoob
There might be some available in autodesks mapping program, but im not sure. : http://www.autodesk.com/products/autocad-map-3d/overview
If you already have you map and you just need the call out location you can create your navaids as a block with attributes.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
https://knowledge.autodesk.com/support/autocad/getting-started/caas/CloudHelp/cloudhelp/2016/ENU/Aut...
CADnoob
