I'm trying to print a new copy of this sheet because I made a minor revision to it and need to re-submit it but every time I try to print, these strange lines show up in the print preview and the actual print. It's hard to erase or turn off something that you don't know what/where it is. I have gone into model space in the viewport to try and window/select these mystery lines but nothing is there, yet when I print, something is there. This is what the sheet looks like on my screen and what the print should look like (other than print will be black and white):
This is how it should look, no mystery lines
This is the print preview:
I have audited, recovered, re-started my computer, never seen these lines before in my life and cannot figure out how to make them go away 😞 I found a sort of similar problem in a forum post earlier and that person copied their drawing into a new drawing and resolved that way, unless that means doing a "save as" then this drawing has close to 20 paperspace sheets and all kinds of stuff like that which would make copying to a new drawing very obnoxious. This project is already under construction and I have printed this sheet numerous times before with no issues but need to print it now to submit for a revision to my construction limits. Please help!!!!!!!!!!!!!
