My PDF file is not showing all my contours
I have been using auto ad civil 3D 2012. I have created a surface for my contour line and trying to convert the drawing to PDF. In PDF, some of page shows the contour line and the rest is showing no contour ? The surface is in one layer. Any help
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which command did you use to "convert to PDF"?
If you used command _PLOT or command _PUBLISH ... which printer-/plotter driver did you use?
Can you please show the drawing as well as the PDF you get. At the moment I can't understand why Civil 3D should not present the contours just for a part of the page".
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
ara_neresesian
hi
in plot or print increase pen width
if its a large area try to pick windows smaller
by the way u can do it in plot option
Capture.JPGI'm using output then export. I'm sending a screen shot
here it's
Alfred.NESWADBA
Please use _PLOT, it's the better option and you do have more control over the content of the PDF
BTW: I do see contours ... what are you missing now exactly?
If there is an option to test with your drawing that might be the fastest way to a solution 😉
- alfred -
Alfred NESWADBA
