My line type scales are different from model space to paper space.
asherjoh
asherjoh
My line type scales are different from model space to paper space. The lts in paper space is a lot larger. I have gone through much online info to get to the bottom of this with no success. I have lts at 1, celtscale 1, pslts 1 and msltale 1. Any other  things I can try on this subject?
0 Me gusta
Responder
Soluciones aceptadas (2)
11.741 Vistas
8 Respuestas
Respuestas (8)
Alfred.NESWADBA
Solución aceptada
if you have MSLTSCALE set to 1 and also PSLTSCALE set to 1 then the modelspace will only show the same ltscale for objects if you give the modelspace the same ANNOSCALE as the scale setting for the viewport in paperspace.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @asherjoh,
It sounds like you are going the right direction.
LTSCALE
MSLTSCALE
PSLTSCALE
CELTSCLE
MSLTSCALE Overrides LTSCALE and CELTSCALE in Modelspace, but it doesn’t effect Paperspace, so it won’t change how your geometry looks inside your viewports.
What are the values yo uhave set for all of the variables? I assume that you are also performing a REGENALL to view changes.
What also is the Annotation scale set to for the viewport(s)
Please feel free to attach a drawing to if you want me to look at it.
John Vellek
asherjoh
All values are set to 1. I usually print at 1/4" to foot scale. Thanks
0 Me gusta
asherjoh
This seems to be the missing info I need. Thank You.
0 Me gusta
IkaroFalcao
Solución aceptada
Try unchecking the "user paper space units for scaling" at linetype manager.
chenchri
Have you tried PSLTSCALE 0?
Christopher Chen
AutoCAD Test Development
asherjoh
That worked also. Thans
0 Me gusta
asherjoh
I dont see that it changes it.
0 Me gusta
