multiple revision levels in the same drawing
My question is in regard to revision levels within the same drawing. If a revision is made to a drawing, that revision gets clouded and identified with a revision triangle. Once the drawings are submitted, the customer comes back with something else that needs revised. That revision is made, clouded and identified with the next revision level and resubmitted.
The current policy here where I work is that all of the revision clouds and triangles remain throughout the set of drawings. In other words, after a revision #1 is made and submitted, the next revision (#2) is made to the drawings, but the revision #1 clouds and triangles must remain on the drawings. It is completely feasible to have 3 or 4 revision levels on a set of drawings. And by the last revision, there are multiple clouds and triangles on the set, which can sometimes lead to confusion and clutter.
My argument is that once a revision level is reviewed and accepted by the customer/architect, any further revisions result in only the current revisions being clouded and identified. All previous clouds and triangles need to be removed (or the layer turned off) as they are no longer part of the current revision. Each subsequent revision to the drawings should only contain the revision clouds and triangles pertinent to that particular revision.
What I am asking for here is input from other folks regarding this matter. What are your drafting policies? Am I wrong in how I approach revisions? Is there a written AIA standard supporting or rebuking my position?
ALL opinions are welcome!
