Multiple polylines chamfer/fillet !!!
maramuresul
maramuresul
If I have multiple polylines that are splited at corners. It is possible to make one polyline in the same way as using command chamfer(dist1 and dist2=0) or fillet (radius=0), but for a multiple of polylines, all polyline that have one vertex in the same position.
Please find attached.
Thanks.
Alfred.NESWADBA
you can run command _JOIN on multiple entities with one step, you can also run command _PEDIT with option _MULTIPLE (use this option before you select the first entity) and then select multiple lines/polylines and connect them by option _JOIN.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Vinayv4v
Here is a Lisp to chamfer as per given distance.
It will only work on LINES (not polylines).
After loading the command from APPLOAD enter command CHAMDIST.
Cheers,
Vinay Vijayakumaran
