Multiple points imported combined into single object automatically
florenceyi
florenceyi
Community Visitor
Community Visitor
When I try to import multiple points from excel, my multiple points appear as 1 object only in my autocad 2020. (Let say I have 8 points, those 8 points they fold together. When I select the object and work 'erase' command, command bar tell me i have deleted 8 objects.
What I do to import points is that:
I use 'concatenate' in excel
I click 'multiple point' command in autocad
I copy the points coordinate from excel then paste them in the command bar of autocad
Then condition as above happen....
imadHabash
I'm afraid that you have a size problem for the inserted points .. Since it says that you have  8 objects then I suggest to check your points size .
Imad Habash
