Multiple plot in single model space
Dear All,
how to plot drawing from single model space in autocad?
for illustration I attached border for model drawing.
Yudika
piyush.parihar24
This is not possible because in every second drawing your co-ordinates will be different. If Co-ordinate are fix then you can find a way out by script or lisping.
Piyush Parihar
imadHabash
In MODEL space you have to repeat plot procedur for all sheet drawings BUT if you want to make it automatically plotting procedur you have to use LAYOUTS which will help alot and by PUBLISH command line.
Imad Habash
piyush.parihar24
You can also set viewport of each section and use publish plot command to perform action.
This is just another solution. This also may help you out.
AutoCAD Certified Professional 2011 / 2012 / 2013
AutoCAD Certified Association 2011 / 2012
Please mark this as the solution if it resolves your issue.Kudos gladly accepted. ⇘
@Anonymous wrote:
Dear All,
Yudika
