Multiple instances of application
Message 1 of 10
I have tried all available solutions online like setting the SDI to 0, or verifying if it was set at 0. and also the technical support team tried to resolve this issue , but failed. They directed me to contact Autodesk.
Issue: Each time I open a new drawing in AutoCAD 2017 LT, the drawing opens in a new window, like re-loading the application, which is about a 15-20 second wait time.
Replies (9)
Message 2 of 10
Patchy
Message 3 of 10
I have mentioned above , that the tech support team has tried all the suggestions in that page. Only task remaining is to uninstall the software completely and re-installing it, but I highly doubt that it might be a waste time.
Message 4 of 10
Patchy
I always thought SDI using 1 opens 1 drawing
0 opens multiple.
Sure you mentioned it, how can I guess the method they used.
Message 5 of 10
Would you know of any other solution? Maybe an Autodesk support could troubleshoot this problem remotely?
Message 6 of 10
TheCADnoob
what steps are you taking to open a new drawing? (opening from within autocad or opening from your OS's explorer)
CADnoob
Message 7 of 10
Well  I double click on the drawing file, in this case a new instance happens, otherwise when I open a file from the application window, it opens in the same window, in a new tab.
Message 8 of 10
TheCADnoob
edit :DOH that was already suggested
Have you tried right clicking and running the program as administrator? or more correctly logging in as administrator.
CADnoob
Message 9 of 10
Patchy
Often missed, but changing SDI then restart the PC to make it works.
Message 10 of 10
pendean
Community Legend
Community Legend
>>>...otherwise when I open a file from the application window, it opens in the same window...<<<
OPEN command is the best way to open a new drawing: any reason you shy away from using it more often?
>>>... I double click on the drawing file, in this case a new instance happens...<<<
There is nothing inside AutoCAD to address why Windows OS is opening new sessions. What is the application associated with the DWG file in Windows Explorer? Explained here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Double...
