multileaders
multileaders
Akunkinga
multileaders
Akunkinga
I am trying to add several leaders to one note but each time i add a leader to the first one it creates another landing line  I only want the one landing line how do i change this
also what is quickest way to change ortho off and on
Accepted solutions (3)
Kent1Cooper
@Akunkinga wrote:
.... what is quickest way to change ortho off and on
F8
or this icon in the status bar:
For the leaders, it doesn't do that for me, except when I go closer to the other side of the text part.  Is that what you mean?
Kent Cooper, AIA
coffeejeanpaul
Good day sir.
Are you talking about one call out/note but multiple points from it.
If so in annotate tab there is a command called add leaders, this will let you add multiple strings to one note.
 hope it helps
Akunkinga
I do use the add leader but find it quite frustrating as if i try to move the 2nd leader it drags the landing line with it. I want multiple arrows from one landing line.
im thinking it might be to do with the ortho settings maybe i should turn them off
pendean
Community Legend
Community Legend
>>>...I want multiple arrows from one landing line...<<<
MLEADERs have the MLEADEREDIT command that offers an add-a-leader option that is exceptionally smooth to use and operate, there is even a preset button for it if you are so inclined in the ribbon https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
