Multileader with block and mtext , field or tag
GB-CHHQ5
Message 1 of 20
GB-CHHQ5
Hi
I was able to create the multileader with a block but I can't get the text next to it to be editable if I make part of the block is there another way that I can have the multileader with the box and the text next yo it to be one ? I included an image and the text with the red cloud is what I need to be able to edit.
Any ideas?
@imadHabash
Replies (19)
Message 2 of 20
vinodkl
mtext inside a block cannot be edited normally and also when you use it in multileader. You need to create an attribute inside the block and use this block for the multileader to make it editable. See attachment.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 20
imadHabash
if your source block is a user block then you have to make it as an attribute by ATTDEF command . finish your attribute and place it where ever your need . convert the box and the attribute to a block and make your insertion from where the mleader will attached with . see attached CAD dwg
Imad Habash
Message 4 of 20
GB-CHHQ5
Very close to what I need, I need to have multiple text lines and that the text on the side is the same size as the one inside the box and also when moving around the label the text ends on top of leader line...
@vinodkl
Message 5 of 20
GB-CHHQ5
Very helpful!!  is it possible to add extra text lines next to the box?
@imadHabash
Message 6 of 20
imadHabash
Yes you can . as much as you make attributes , those cells will be active .  OR while you're making attribute select Multiple Lines option . see below image .
Imad Habash
Message 7 of 20
GB-CHHQ5
I'll give it a try! also when you add the attribute can you set a distance with the box to avoid having overlapping text ?
@imadHabash
Message 8 of 20
vinodkl
You could create a multiline attribute for the left side one and can enter the value just like mtext. But it's not possible to have the attribute text on the left to flip when the arrow is moved to either direction. Instead, you could place the attribute text on the top of the block or below so that it doesn't interfere with the arrow. See attachment.
Message 9 of 20
GB-CHHQ5
Very close to what I need, I'm just having trouble adding text it start's to overlap with the one in the box.
@vinodkl
Message 10 of 20
vinodkl
I guess the attribute justification is set to "center" that's why it could be overlapping. Can you check the justification of the attribute? Click on the attribute and then press ctrl+1 for properties and then check the justification and set it to top left. If it doesn't help then please attach the drawing so that we can see why it's happening🙂
Message 11 of 20
GB-CHHQ5
Already try and it doesn't show the justification
@vinodkl
Message 12 of 20
vinodkl
Any changes to be made in the attribute you need to go into the block editor. Type in the command "BEDIT" and then choose the block which you have used in the multileader then click on ok. now edit the justification of the attribute inside the block editor and save changes. These changes will be reflected in the multileader.
Message 13 of 20
GB-CHHQ5
On the block it works, once I create the multileader it does the same thing and I don't a can't use that menu with the multileader to adjust them, on properties does show it.
 @vinodkl
Message 14 of 20
vinodkl
Are you sure that the block which you edited and the block used in the multileader are the same? Can you try to draw a multileader again with the same block name and then see it gets corrected in the new multileader. Also, Try posting you drawing file so that we can check it out from our end as well🙂
Message 15 of 20
imadHabash
The idea is before convert your attribute to block is to prepare and finish your text justification from Justify option in properties palette .
Imad Habash
Message 16 of 20
GB-CHHQ5
Still having issues I attached the dwg.
@imadHabash @vinodkl
Message 17 of 20
imadHabash
your  MLEADERSTYLE # 1  is ok .  the space in the box is just for 3 digits or characters , if more it will go out . if it's not clear please don't hesitate to ask and more specifically . 🙂
Imad Habash
Message 18 of 20
vinodkl
The maximum number which can fit inside the box is 3. If you enter more than 3 then it would overlap with the other attributes. If you want to enter more than 3 digits then try to make the box as a rectangle so that you can enter more digits.
Message 19 of 20
cwr-pae
Look in to using BATTMAN (Block Attribute manager) to adjust blocks after they are created. The sync button apllies the changes to all instances of the block in the current drawing.
Also I attached 3 example dynamic blocks with adjustable frames for use with qleaders, using QLATTACH to associated leaders to the block. Not as convenient as multileaders but more workable for adaptable text frames.
The last block has the leader as part of the block to act more like a multileader.
Hope these help you create what you need.
Message 20 of 20
khujamat
Community Visitor
Community Visitor
how can i use this for elevation levels. Thanks
