Anuncios
Multileader Leader Connection
dan4UYYZ
dan4UYYZ
I have four lines of text in my Multileader, has any one figured out how to underline the second line? My only choices are underline top and bottom line. Would be helpful if anyone has a solution.
Thank you,
0 Me gusta
Responder
Soluciones aceptadas (2)
325 Vistas
4 Respuestas
Respuestas (4)
cadffm
Solución aceptada
I think there is no solution, Acad offering two options, that is all.
Ever tried to set up your own custom BLOCKs with Attributes for this case (instead of MText option)?
Sebastian
0 Me gusta
dan4UYYZ
Thank you for responding. I figured that was my only option was to create blocks with attributes. Hope someday Autodesk will add more than just underline top or bottom of text line in their multileader. Thank you so much for searching for a solution.
Dan
0 Me gusta
ВeekeeCZ
Solución aceptada
Well, since you have 4 lines, you can use the middle of the text option...
dan4UYYZ
Hi
i also have one question if there is a lisp routine or command that I can match properties of one multileader to another multileader by angle rotation?
thank you
dan
0 Me gusta
