Multileader block scales wrong
camilorb36
camilorb36
Community Visitor
Community Visitor
Hi, I create an annotative multileader style to enumerate downpipes, and it have a non annotative block with attributes to place number and description. Almost works ok, but when I use the multileader, the block automatically scale according to drawing units, but I don't need it because the multileader is already annotative. The block is draw in milimmeters, so when I change the scale on properties pannel to 1.0 it shows well, I don't know how to make it display well.
Here is the default setting scale in a meters dwg
Here how it displays when I change manually to 1.0 (the correct display)
I need the scale to always be 1.0. I tried to change the block to annotative but didn't give results, and the scale in the Multileader pannel is set to 1.0, so I can't understand why when I use it, the scale is different to 1.0.
Thanks for reading and I await to your contributions.
VincentSheehan
You can either scale the contents in the block or adjust the scale within MLEADERSTYLE.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
