AutoCAD Forum
Multi Selection and replace
3 REPLIES 3
Pablo_Gonzalez87Y5H
273 Views, 3 Replies
Hi Community,
I need to do a selection of hundreds of items, they are already in layers, I know how to make the Qselect,
My problem begins when I have to replace these multiple items with a new one.
The original items it is an arch, or half a circle, I need to select all of them and replace them with something else.
Is there a way to do this?
I really want to save myself some time and not replacing one by one, I just don't have the time.
3 REPLIES 3
Get their center points and put a block at those points.
@Pablo_Gonzalez87Y5H wrote:
.... The original items it is an arch, or half a circle, I need to select all of them and replace them with something else.  ....
That would be greatly affected by exactly what the "something else" is.  A Poiht at the Arc center?  A Block with its insertion point there?  A Line across the chord between its ends?  An Arc of a different size?  Text of some kind?  And is the arch an Arc object specifically, or something else, such as a Block, a Polyline arc segment [or more than one], a partial Ellipse with equal axes?  Etc., etc.
Kent Cooper, AIA
@Pablo_Gonzalez87Y5H What you are asking for works best if EVERYTHING is a block with a shared or common INSERTION POINT and possibly even orientation. Are they? If not, that's going to be a challenge to replace perfectly.
Can you share your DWG file and a copy of that "something else"?
Forma Design Contest
