Anuncios
Multi lines structure - Axis (defpoints)
andres_bonilla
andres_bonilla
Greetings to all,
Is it possible to assign the 'Defpoints' layer to one of the layers to create a type of multiline? In particular that I require to have the central axis of my 'wall' but I require that it not be printed, is this possible?
Currently I have assigned the color 255,255,255 (total white) but in some cases it covers some elements of my drawing.Wall type - Multiline.jpg
Thank you in advance for your answers.
Have a nice day!
0 Me gusta
Responder
329 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
MLSTYLE has no such ability, sorry: if these are 'walls', are you using AutoCADARCHITECTURE or plain AutoCAD?
>>>...but in some cases it covers some elements of my drawing....<<<
DRAWORDER should fix that, but it affects your entire "wall". Is that an option?
HTH
0 Me gusta
andres_bonilla
Hi, thank you for your answer.
In fact I'm using the standard AutoCAD, as for the use of the drawing order, I use it, but this does not change the fact that the center line affects my drawing a little.
The simplest option I'm thinking of is to use a line color (grey) with the lowest transparency level (20%).
If anyone discovers or knows of another option, I'm all ears! :cara_con_una_leve_sonrisa:
Thanks.
0 Me gusta
