Message 1 of 12
08:18 AM
I've got dimension text issues when I use a multi-line text (one line above and one below the dimension).
My dimension style is set up to put the alternate units below the primary units, it looks like this:
That's perfect. Now, let's say I want to move the text to the outside. Watch what happens to the vertical offset of the lower line of text:
Even worse is when I move the text back to its original centered position:
This looks very sloppy - how can I fix it? The behavior is exactly the same if I don't have alternate units but use \X to start a second line.
