MTEXT command doesn't remember last used settings
12:37 AM
As I mentioned in the post title, autocad uses the default value each time I create multiline text although I change the value in previously run MTEXT command. The case is not the same when using TEXT command, it remembers the last set value. I don't want to change the default value (TEXTSIZE works but this path is longer if I follow each time) but I want the last settings to be remembered.
I use Autocad 2018. Size is set to 0 in Text Style window.
Thanks in advance.
