Anuncios
MTEXT border/box automatic resize based on text length
No aplicable
I was resizing a drawing and the mtext box was bigger than the text so it streched aand moved the text outside of the required place...is there any awyto confine the border of the mtext to the text length after the text has been typed ( i want to select all mtext and do this in one go)
Single text box stretched all the waySingle text box stretched all the way
0 Me gusta
Responder
747 Vistas
1 Respuesta
Respuesta (1)
injineri
don't know about automatic frame but when texts are drawn you can select all, then from properties panel you can remove "columns" from text and set "defined width" to desired value and text grips will be set as you wish
