Moving objects USING SHIFT KEY AND SCROLL BUTTON ON MOUSE
My computer at school will let me rotate my drawing using the shift key and mouse scroll button.  How can I set this on my home computer?
imadHabash
would you check if your setting is the same as below image and from CUI command. and make sure please that you are hold Shift + Wheel (in that order) .
Imad Habash
I may be using the wrong terminology.  I can rotate my drawing to look or see different views on the screen by using the shift key and the mouse scroll wheel.
gotphish001
Nevermind.
Nick DiPietro
Cad Manager/Monkey
I am using AutoCad 2018 and that is not working. I have tried shift left mo=
use button, shift scroll wheel and does not work. I have reset the program =
to default and it still does not work.=C2=A0 I am new to AutoCad and am tak=
ing a class in 3d. I am weeks behind because of this problem on my home com=
puter.=C2=A0 Is there any command that will correct this problem?My instruc=
tor is also unable to rectify the problem
