Moving Drawing From TOP View To FRONT VIEW.
0171352
0171352
Hi guys, I'm new to the forums and this would be my first time posting here. I'm new to autocad and I was looking for an way to move my sketch into the front plane because by mistake instead of sketching it on the front plane I sketched on the top plane. Is there any way if i can transfer this drawing from the top plane to the front plane? I'm using Autocad 2018 Student Edition.
0 Me gusta
Responder
Soluciones aceptadas (1)
25.670 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
commands _3DROTATE and _ROTATE3D, both can do that.
Also if you first set your UCS to right or left you can use command _ROTATE).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
0171352
Thank you Alfred, it seems to work but I need to 3drotate to the Y-AXIS. Is there anyway I can go to the Y-AXIS Because When I rotate it I'm on the X-AXIS.
Update: I got it to work I used the Gimizos In 3D Tools.
Thank you Alfred, It works great!
0 Me gusta
