Anuncios
Moving between versions
No aplicable
Is it possible to move drawings from AutoCAD 12 to 13 and vice versa?
0 Me gusta
Responder
299 Vistas
3 Respuestas
Respuestas (3)
No aplicable
If your drawing format version lower than 2013, You can use it in the both 2012 and 2013.
0 Me gusta
ennujozlagam
yes can be done vice versa and in options you can saveas your drawings that can be opened in lower version. thanks
0 Me gusta
imadHabash
you can deal with dwg files depending on file format that you use. each AutoCAD-based product uses a specific file format when saving to a file, which is important when sharing files. The following table outlines which file format should be used when sharing files with other users of AutoCAD or AutoCAD-based products:
File Format AutoCAD Release
AutoCAD 2018 AutoCAD 2018
AutoCAD 2013 AutoCAD 2013 - AutoCAD 2017
AutoCAD 2010 AutoCAD 2010 - AutoCAD 2012
AutoCAD 2007 AutoCAD 2007 - AutoCAD 2009
AutoCAD 2004 AutoCAD 2004 - AutoCAD 2006
AutoCAD 2000 AutoCAD 2000 - AutoCAD 2002
AutoCAD R14 AutoCAD R14
AutoCAD R12 DXF AutoCAD R12
Imad Habash
0 Me gusta
