Moving an object in one viewport without it moving in the other
more0337
Observer Observer
Message 1 of 8
more0337
Observer
Observer
Hello guys.
I have two viewports in autocad. The left one should be at a scale of 1:20 and the right one should be at a scale of 1:10. Is there any way to move an object only in the 1:10 viewport while making sure it doesn`t move in the 1:20 viewport?
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
@more0337 wrote:
...I have two viewports in autocad...
.. Is there any way to move an object only in...
Are you trying to move/adjust annotative text/dimension/attributes or block locations between the two scaled viewports in your layout? Or something else?
Sharing screenshots might help you explain it.
Message 3 of 8
more0337
Observer
Observer
Yeah sure. I would love to send a screenshot. I just don`t know how to show a screenshot here.
Message 4 of 8
paullimapa
Short answer is no, since vports are basically views looking into your drawing in model.
If you move the object in model, then any vport in layout looking at those objects will show them moved.
Paul Li
IT Specialist
@The Office
Message 5 of 8
Kent1Cooper
@more0337 wrote:
.... I just don`t know how to show a screenshot here.
One way is to use the Windows Accessory "Snipping Tool" or the "Snip & Sketch" function [they're quite similar].  Once you have snipped, you can simply Ctrl+V Paste what you snipped into a Message here -- you don't even need to save it to a file or anything.
Kent Cooper, AIA
Message 6 of 8
ВeekeeCZ
@more0337 wrote:
Hello guys.
If that object is an "annotation" (m/text, m/leader... ), you can move it in different scales of it independently.
It's independent by scale, not by viewport.
Message 7 of 8
ВeekeeCZ
...just paste it into a message window.
Message 8 of 8
pendean
Community Legend
Community Legend
https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
