AutoCAD Forum
MOVEBAK to relative path
4 REPLIES 4
kibitotato
367 Views, 4 Replies
kibitotato
¿Is it possible to use MOVEBAK to a relative path?
Use .\folderdestination
Instead of C:\folder1\folderdestination
Tags (1)
4 REPLIES 4
pendean
in reply to: kibitotato
pendean
Community Legend
Community Legend
Nope.
Nope.
rkmcswain
rkmcswain
You can technically set a relative path, but MOVEBAK won't honor it.
https://blog.jtbworld.com/2007/07/movebak-for-autocad.html
kibitotato
in reply to: rkmcswain
kibitotato
How? I read the post, try to type (setenv "AcetMovebak" ".\folderdestination") but deosn´t work...
paullimapa
paullimapa
Since it doesn't accept relative path, as an alternative you can have AutoCAD always run the following code every time you open a dwg:
(if(not(vl-file-directory-p (setq fld(strcat(getvar"dwgprefix")"Backup"))))(vl-mkdir fld))(setenv "AcetMovebak" fld)
Then the backups will be saved under the Backup folder relative to the current folder location of the opened drawing.
You'll also need to redefine the SAVEAS command so that this is invoked after saving the drawing to a new folder location.
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
