Move Sketch from current UCS to new UCS projected along Z axis
cjackson2N65T
cjackson2N65T
I am working with a point cloud and would like to move my plan view drawing "up" in the Z axis direction to clear the top of the point cloud. I have created a new UCS that is projected a distance above the current UCS in the Z direction, let's say (0,0,50) units above the current UCS origin). How do I move the sketch from the current UCS to this new UCS so that only the drawing's Z coordinate changes, that is, everything is aligned, it just sits on the XY plane of this elevated UCS?
0 Me gusta
Responder
Soluciones aceptadas (2)
442 Vistas
6 Respuestas
Respuestas (6)
imadHabash
Solución aceptada
Hi and Welcome to AutoCAD Forum,
Select all of your CAD elements after activating MOVE command then select 0,0,0 for start point. Now you can specify your Z value for Second point by using coordinate as described Here
Imad Habash
0 Me gusta
cjackson2N65T
Thanks for finding a solution. Can you tell me how to find the Z coordinate value of the new UCS so I can be sure that when I use the MOVE command, it puts the drawing on exact level of the new UCS XY plane? When I click on the existing UCS, its PROPERTIES tab does not show me its XYZ coordinates like I'd see if I clicked on a line (Start Z, End Z, etc.). I would assume there is some way to find a UCS's coordinates relative to the WCS?
0 Me gusta
imadHabash
I suggest to try ID (Command).
Imad Habash
0 Me gusta
cjackson2N65T
When I use ID at the new UCS origin, it returns (0,0,0). I need to know the new UCS coordinates relative to the WCS or relative to the original UCS that I want to move the drawing from.
0 Me gusta
imadHabash
Solución aceptada
Click on below image that i hope will give a hint...
Imad Habash
0 Me gusta
cjackson2N65T
Thank you for your help. I made a line on the new UCS, switched to the original UCS, used the change (command) to find the elevation, so now I know how far the new UCS is from the original UCS.
0 Me gusta
