Move/Copy Objects with Specified Distance Snaps to Midpoint
jarredmonday
jarredmonday
This issue has appeared out of nowhere. If i have the osnap turned on and I move or copy an object and it is on another object, it will snap to the midpoint even though i am typing in the specific distance. if i turn off the osnap this will not happen. What setting am I not aware of that is making this happen? I don't remember it being like this before. Thank you.
See video for reference.
Objective: Copy circle 48" up the green line.
ObjectSnap Settings: ON
Technique: Copy circle then specify distance.
Result: Circle will snap to the midpoint of the Line.
ObjectSnap Settings: OFF
Result: Circle will be copied to specified distance without issue.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
StephenThomasGrace
Try OSNAPCOORD
Should be set to 2 to keep snaps from overriding keyboard entries.
-steve
jarredmonday
Yes, indeed it should be. My machine was set to zero. I don't know what caused that. Thank you for the reply.
