Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
before changing computer the mouse wheel was working perfectly. I used it only for zoom in and out and for PAN the drawing constantly.
Now I have a new computer and when installing Autocad again in this computer, the wheel starts PAN, but almost immediately it provokes a zoom to the extents of a drawing that makes it impossible for me to work properly.
what do I need to redefine to avoid this. I never need to make a Zoom to the extents of a drawing with the wheel
That means the mouse is thinking you did a double-click.
This can be a setting in the mouse driver, or a critical (hyper sensitive button/contact).
I would start to change the mouse to another one you have and see if that works better then.
- alfred -
>> I did...and all reacted the same..
All from the same manufacturer? Then I guess you have to look to the mouse driver options (in control panel ==> mouse ==> and see how the wheel -click is configured)
- alfred -
I see that I can only define in the control panel the scroll function of the central wheel of the mouse (the amount of lines I can scroll) but I cannot get out the double click function.
do you know how to take this Zoom extent out of the central wheel of the mouse in Autocad?
I only need to zoom in and our with that wheel when working with Autocad
For someone who want a software solution to this problem. I find a similar question on forums.autodesk.com (http://forums.autodesk.com/t5/AutoCAD-2000-2000i-2002-DWG/Disabling-Wheel-Button-Double-click/td-p/2...), But there is no answer either.
copy the following code to a blank text file and save it as acadMbutton.ahk.
MButton::
If (A_TimeSincePriorHotkey < 300) ;hyperclick
Return
Click Down Middle
KeyWait, MButton
Click Up Middle
Return
WheelDown::
If GetKeyState("MButton")
Return
Send {WheelDown}
Return
WheelUp::
Return
Send {WheelUp}
Return
Download Autohotkey from http://l.autohotkey.net/, and run the script with Autohotkey
This script do two things:
1. disable very quick middle button double click, if you set the time to large enough, for example 2000, it will disable double click complelely
2. disable mouse wheel while the middle button is pressed down
Cheers,
Vinay Vijayakumaran
For what it's worth this happened to me and found altering (speeding up) the Double Click speed sorted it.
On Win 10 Settings > Devices > Mouse > Additional Mouse Options [link on RH side]
Launches the old style mouse control tabbed dialog (here anyway) where Buttons [Tab] has double click speed.
Mine was near middle, slid right a couple of clicks sorted it.
Robin
AEC Collection & BIM 360 | Windows Surface Book & HP Z6 Workstation | Android Mobile
