Mouse drivers' uncompatible with autocad 2017
Message 1 of 8
I'm using Autocad 2017 with latest service pack and Evoluent vertical mouse 4 in which I've placed keystroke recordings through Evoluent mouse manager v.5.7.0.1. How ever now every basic command like Move and rotate has over 2s delay before I can give base point. But there's no dealy if I disable the manager.
Anyone else have encountered this kind of problem? Does some other mouse for example logitech with programmable buttons have the same problem?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Have you docked your command-line or is it just the one-line appearance close to the bottom of the application window?
I prefer to dock it, it makes the input easier.
You might also look into the settings of command _INPUTSEARCHOPTIONS and disable options to see if it works then better.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
Command-line is docked to the bottom and I disabled all search options and had no effect. Problem isn't in giving and accpeting the commands, but giving basepoint for them.
When autocad asks to "specify base point or.. (coordinates) ", that's where the delay is. For two seconds it doesn't let me choose any point.
We tried with basic mouse too and with it there's no delay so it clearly seems to be in the evoluent drivers.
-Matti
Message 4 of 8
Alfred.NESWADBA
That is an important point, so it really seems to be not depending on AutoCAD ...
Sorry to not be able to help you with that as I don't have this mouse.
- alfred -
Alfred NESWADBA
Message 5 of 8
My friend found solution to this! It's not even about Evoluent drivers but Windows 10 touchpad settings. I set the touchpad delay to no delay in Settings under Mouse and touchpad in Windows 10 and after that it works normally without delay again. I also tried to put longest delay and it had clear effect.
-Matti
Message 6 of 8
Alfred.NESWADBA
Great! Thank you for letting us know that!
- alfred -
Alfred NESWADBA
Message 7 of 8
I have the same problem but i do not understand this solution. I do not have a delay setting for my touchpad
Message 8 of 8
Set the touch pad sensitivity setting to "most sensitive" Problem solved
