mouse button two macro default
Message 1 of 8
Can anyone tell me what the default macro is for the second button on a mouse? I changed it and want to change it back. thanks!
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Your mouse driver determines what your mouse buttons do: what did you change exactly and what do you want to change it back to?
Message 3 of 8
to whatever is the default when installing CAD 2020
Message 4 of 8
NVM I figured it out
Message 5 of 8
pendean
Community Legend
Community Legend
What do you have for these settings?
Message 6 of 8
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,5),GRIP_),$P0=ACAD.GRIPS $P0=*);
That's what it was originally
Message 7 of 8
ambrosl
Where did you make the change to the macro?  Did you use the CUI command/Customize User Interface editor?
If you used the CUI Editor, and changed the macro for "Button 2" under Mouse Buttons > Click then the default macro is as follows:
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Message 8 of 8
That's correct. But like I said, it's all set now
