AutoCAD Forum
Most objects do not export when opening my DWG File in other programs
3 REPLIES 3
1144 Views, 3 Replies
every time I open any other program it comes like this... I have already tried opening in 3dsmax and exporting in 3ds, but it always comes missing objects. Help me pls ❤️
3 REPLIES 3
Alfred.NESWADBA
Which file format did you use to export data from AutoCAD?
3DS is a very old format to exchange 3D-faces, but keep in mind that 3DS-format can't handle complex geometries. It has a limit of max. number of vertices for one object, that could be a reason that you don't get all objects exported to 3DS.
Please let us know which software exactly you are using to create the geometry and which software is the one you need the geometry to import.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Alfred, thanks for replying. I import to CAST WYSIWYG R36 the DWG file. Finally, I did import to wyg the file and it worked , but the wireframe view lagging so muchh! Have any way to make the truss simpler?
Alfred.NESWADBA
Sorry, never heard that, so I don't know that product.
So you have got now all objects transferred?
That depends on what objects you have in your drawing and what type of objects this other application receives when it's opening the dwg-file.
I would create a simple drawing, create one box (3D-Solid) in AutoCAD, save that drawing, import in CAST.... if that works I would look in your primary drawing to make sure all objects, that are 3D-Solids, are exported using command _WBLOCK to a new drawing, then use this drawing in CAST ... better now? Anything missing? If there are objects missed then look to your AutoCAD which types of objects the missing ones are.
- alfred -
Alfred NESWADBA
Forma Design Contest
