AutoCAD Forum
Monochrome. Ctb not showing and stretch command not working
12 REPLIES 12
Message 1 of 13
20DBV46
821 Views, 12 Replies
The monochrome. Ctb is not showing on my Autocad 2018
Tge stretch command is not working either
12 REPLIES 12
Message 2 of 13
pendean
in reply to: 20DBV46
2018 is not new: so what is different with your setup today?
Do you see any CTB files? Or are you only seeing STB files? start a new blank drawing, does it show up?
"not working" doesn't tell us much, start a new empty drawing and try it, does it work there?
Message 3 of 13
imadHabash
type STYLESMANAGER and check if it's exist . if NOT , you may need to copy it from another PC .
tell us more please how it's not working ?
Imad Habash
Message 4 of 13
not sure about the stretch command. are your .ctb files stored locally or on a network? ACAD needs to be able to find them straight away once opened... you can redirect the file path if needed within:
tolls>options>printer support file path> plot style table search path
Message 5 of 13
20DBV46
in reply to: pendean
I only see stb files
Message 6 of 13
20DBV46
in reply to: imadHabash
I opened the stylemanager.and the file does exists. How do I import it to the plots style table?
Message 7 of 13
That explains it, stb files are named plot styles and work very differently to ctb files which are color dependent.
plot style types are applicable to individual .dwg files. There is a system variable called something along the lines of convertptstyle.
Message 8 of 13
20DBV46
I opened the style manager the files are stored locally
Message 9 of 13
20DBV46
And how do I convert?
Message 10 of 13
imadHabash
type  Convertctb command . >> Click <<
Imad Habash
Message 11 of 13
Message 12 of 13
cadffm
Oh. I am slow today. You don't need an import, but DWG files are set up for color depended OR named plotstyletables.
For new files, check your pstylepolicy,
For new files based on a template, take the right template,
for existing files, convert by command convertpstyles.
But think about: If the drawing was setup well to use stb, you will loose the plotstyle information.
(Read more about plotstyles ctb and stb)
Sebastian
Message 13 of 13
20DBV46
in reply to: cadffm
Thanks for the help. I learn how to convert stb to ctb
Forma Design Contest
